Feasibility of EFI conversion 125cc motorcycle
I'm new to this forum and EFI in general.
I am trying to figure out if a fuel only (initially) EFI conversion on my MZ RT125 motorcycle is feasible.
The bike uses a Mikuni VM24 carb and this feeds a 4 valve single cylinder dual OHC engine. The engine is rated at 11KW output @ 9000rpm.
The first thing I'm worried about is what is the simplest way I could convert the bike? I have a spare carburettor so maybe that could be converted? Or would I have to find a Injection throttle body off another motorcycle? Are there companies who manufacture custom ITB's for motorcycles.
I've had a read of the forum and the forum with successful motorcycle conversions but there aren't many 125cc bikes completed.
I've also registered on the megasquirt forum and had a bit of a read on there.
Can anyone point me to a source for further study?
Thanks.
David.
Re: Feasibility of EFI conversion 125cc motorcycle
Your project sounds entirely feasible, but you just have to pick your parts carefully (I've had fun shocking people with tales of 18k+ redlines and sub-msec idle times...
Custom stuff is out there, but it's usually geared towards the big car engines, and $$$!!!
Good luck!
There are 125cc injected bikes Yamaha, Honda etc in UK and Europe. The Yamaha is a similar output to yours, and I have seen the throttle body/injectors on eBay, but you can also use a quarter of a more common 600cc bike, so you could adapt one throttle body off a 4 cylinder R6, CBR etc, and as you are not looking for huge horsepower, earlier throttle bodies will do...cheaper as well
There is a Honda CBF125 injector body on Ebay at the moment. It's a Honda PGM-F1 unit. Would this unit be OK for the job.
Does anyone know any technical details about these units?
Thanks.
David.
London,UK
- Master Squirter
monstermonkey
Hopefully there may be some info in there that's usefull.
I think the MZ uses a Yamaha engine, MZ have done this a few times, mainly with the bigger bikes (Super Moto 660 is a Yamaha 5 valve) - maybe worth checking.
