Bike died on the dyno
newtyres1
Re: Bike died on the dyno
SQLGUY
- Experienced Squirter
Also, how much of a difference, if any, did the different tach input circuits make, and which one are you using now?
pommie02
the bike will idle fine, it revs cleanly...i could leave it running all day.
but once i try to ride hard, that when it all goes wrong.
the bike starts first time, no messing around.
hopefully there should be a data log included...i am not sure if the 9500 revs means anthing, but once it starts playing around it doesnt stop
newtyres1
What is the rev-limit of the stock igniton system? The only thing I can think of to try is putting a 22uF electrolytic capacitor rated at say 63V (or more) across 12V and ground at each coil, but this is grasping at straws also, but is what I would try next if no-one else comes up with anything. Putting these caps on has helped other installs running other codes, it is not an original idea, some cars come with them standard. If I think of anything else I will let you know.
pommie02
so that should be ok, i was thinking of putting an external globe on the bike and connecting it to each circuit to see if i loose my power.
i am not sure if the relay ignition feed is dropping out or my original bike wiring may be a problem. it all seems a little strange because until i went on the dyno the bike was fine. so whatever isit is you would think the bike dying caused it.
Ian ....these capacitors, how should they be connected ?
newtyres1
Something to try to rule out power loss, is temporarily hardwire the uS to the battery positive terminal via an inline fuse say 500mA or 1A (put the fuse very close to the batt terminal) and then take the bike out for a thrashing. That will isolate the ignition switch, kill switch, relay and other associated wiring.
I suggest that if you don't get any other help here in the next couple of days, post it on the http://www.msefi.com forum with full details (like in one of my posts above) and post the datalog, there is a lot more traffic over there and a lot more people with a lot more experience. After all, uS uses the same MS2 chip and similar code.
Ian.
newtyres1
pommie02
i had hooked up a led to the earth circuit from the microsquirt, when it happens the light goes out.
i just need to find out what is killing that circuit. i have powered up the relay directly ...but the problem is still there.
- Site Admin
pommie02
i am using the opto input from the negative side of my coil.
would this mod help me ?
