first time, please help
akickindanuts
First off, on the red/green O2 gauge on the bottom of MegaTune's start page, is the red rich or lean? My guess has been that it is rich, but any clarification would be appreciated.
Second, my O2 reading has been staying around .8-.9 volts all the time, no matter what I do to the amount of fuel going through the injectors. The only time the red/green gauge goes anywhere near green is under full throttle conditions, when it goes almost all the way down to nothing. I don't fully understand what is going on there.
My last question is about the VE table. I am not really sure what I should be doing with it, if anything at all. The car starts, warms up, and idles perfectly, every time, and even feels and sounds great when accelerating. I am just not sure what I am doing when it comes to adjusting the VE table. Thanks for any help again.
mops
- Experienced Squirter
2. engine details
3. 14.7:1 afr = stoich = proper chemical combustion
less than that (i.e. 10:1) = rich = bit more fuel and normal , engine should be slightly rich in high load areas (12.5:1 for NA and richer for turbo engines) for best power.
more than that (i.e. 16:1) = lean = less fuel than normal. in cruise/coast/low load areas depending on the engine type you should run as lean as you can for fuel economy. running to lean in high load areas is damaging to the engine.
where did you get your ve table that works that great ? did you just generated one ? you might got lucky that it work good for you.
tuning ve table - by adjusting values in the table you adjust afr for particular points. tuning manual describes well what afr's should be run in what conditions, so you should understand it by now and make sure you get desired AFR's at all rpm/map bins.
superfiero
hudsonhawk
akickindanuts
It's a chevy 350, pretty much stock with a 2 injector TB. I am using the default VE table in megatune. I understand what rich and lean are, I just want to know where each is on the O2 gauge in Megatune. And I understand air fuel ratios, I just don't understand how I am supposed to adjust the VE table. When I take it out to drive it, I turn on the "tuning" page in Megatune and watch the VE on the little graph. It kinda jumps all over the place, but generally increases the way it should, until deccelerating, then it drops way down to like less than 20 MAP units, while the RPMs drop. By the way, it idles at around 30 Map units.
mattrampone
