Has Megasquirt been used to control Direct Injection
Has anyone heard of Megasquirt being used in a direct cylinder injection application?
What brand and type of pump/injectors were used with Megasquirt?
Thank you.
EstateAgent
Yes, the MS provides both.triver525 wrote:So MS doesn't provide the ability to control injection timing AND pulse width?
Correct me if im wrong, but direct injection is just reference to the physical side of things. It still injects when needed?
MS still has only 2 injector bank outputs (has otherwise it changed?), so if the injector injects direct into the cylinder (unlike the typical injector on the manifold), then it might be a little waste of fuel/dangerous if the other injector on the bank fires on intake/exhaust.
HTH,
Erik
Check out this thread. I haven't gotten any feedback yet, but I think that Direct injection might be acheivable with minor changes and running one megasquirt per cylinder. I've been pondering buying a small diesel generator (1 or 2 cylinder)to test this idea out on.
It's probably not the answer that your looking for, but maybe it would work.
Dave
