I live in CO, and as you can guess, 30 minutes can easily mean 4000' in elevation variance. Also, getting the motor to fire in the winter is abysmally difficult without a choke. Since I'm a software engineer with emphasis in robotics, I figured MegaSquirt would be pretty trick for my application.
Here's the details of my existing motor. I have some carburetion issues, so the dyno read 11.5 a/f ratio when she pulled 402 RWHP. She should be capable of around 475 or so RWHP once tuned, so I'll build the EFI setup based on that figure.
Here's a rundown on the motor I'm running and hopefully it'll help ya'll guide me to the proper components.
I plan to machine my Victor to accept port injection.408ci Engine Details:
Cubic Inches: 408 (stroked 351W)
Compression: 10.7:1
Crankshaft: SCAT 9000 series
Bore: 4.030
Stroke: 4.00
Rods: SCAT Forged H Beam 6.2"
Pistons: Probe Forged 19.3cc dish
Timing Chain: Edelbrock Double Roller
Oil Pan: Milodon 8qt.
Crank Dampner: Summit SFI
Cylinder Head Details:
Brand & Model: Air Flow Research AFR205
Valves: 2.08 / 1.60
Port Work: CNC ported and polished
Components: Air Flow Research valvesprings
Rockers: Crane Gold 1.6 Roller 3/8 stud ( 974D )
Camshaft Details:
Brand & Model: Crower 15445
Duration adv int/exh (0.050 int/exh): 285/292 (254/260)
Gross lift int/exh: 0.597/0.578
Lobe Separation: 106
Cam advance/retard: -4 degrees
Lifters: Crower mechanical roller
Induction System Details:
Intake: Edelbrock Victor Jr 351W
Port Work: Matched
Carb: Holley 750 Doublepumper ( milled choke horn )
Carb spacer: BG Systems phenolic 1/2" 4 hole spacer
Fuel Pump: Summit high volume
Air Filter: K&N 14x3
Exhaust System Details:
Hedders: Hedman Shorty 351W Swap
Pipe Diameter: 3"
H-Pipe: Yes
Mufflers: Dynomax Super Turbos
Tailpipes: Dump in front of axle
Ignition Details:
Distributor: Mallory Unilite with HEI conversion cap
Ignition: Mallory HyFIRE IVc
Coil: MSD Blaster II
Wires: Ford Motorsport 9mm plug wires
I'm looking at snagging the Edelbrock 3878 Throttle Body
I believe I need around 36lb injectors
I need a wideband O2 sensor. Do I just need the sensor or do I also need a digital gauge or other device? Would THIS work? I currently am using a single wire O2 sensor, but I assume I need wideband, correct?
What temperature sensor do I need? Any part numbers for a 351w?
What fuel pump / regulator do I need? I currently have a 140gph / 15psi pump.
Which MegaSquirt unit do I need?
What else do I need to help it adjust for altitude and weather ( temp )? A day a the dragstrip can see a 6500' to 8500' adjusted elevation swing.
Thanks a TON ya'll!
