2Litre zetec map needed
mrzefect
Post by mrzefect »
I have a 2 litre ford zetec using gsxr 750 moter bike throttle bodys light green injectors is there a map that will get me up and running im using ms 2-2 and spark edis4 and 2.25b514 beta . any help would be thankfull as im a ms virgin.
MR ZEFECT
bubble
Post by bubble »
try using the ve table wizard in megatune it created a startup map that let my engine start and run first time. (MS2, V3, 2.23 and EDIS4) As long as you know the output characteristics of your engine it produces a usable starting point.
Nigel
rs2000
Post by rs2000 »
As bubble says the VE table wizard will get you started for the fuel map. For the ignition map go here http://www.msefi.com/viewtopic.php?p=61835#61835
scroll down the bottom and there is a handy excel file that will give you a base timing map.
mrzefect
Post by mrzefect »
Thanks for your help it is runing but its very very rich on idle so much so it chokes its self and cuts out i have no o2 sensor on it yet do you think it would help also cant fint ve wizzard on my megatune.
MR ZEFECT
MiataMath
Post by MiataMath »
To get to the VE wizard.. go to the VE Table 1.. click tools - VE specific and then generate Table. There it ask you for the HP/Torque information to get your started.
Miata '96, Tein Flex, HDHCDD, MS'n'Spark V3, Fuel only for now.
DIY turbo in mind :)
Triggsy
Post by Triggsy »
I'm running a 2ltr zetec with gsxr 750 throttle bodies and have the map tuned pretty good.
I've attached the ve table here but please be aware that this comes with no guarantee of being suitable for your setup.
Cheers
Simon
mrzefect
Post by mrzefect »
still cant open the file i have been sent over ones and they do the same i still would like them if you can help out also a spark advance table would be very helpfull i have done a set up using a dyno rusults of another zetec with gsxr 1000 throttle bodys using ve wizard and turned the o2 step% to 0 and it idels a 100% better but is still a bit rich but i have a varible reisitor on the dash insted of a warm up sensor i think it might be the wrong value so one way it gets very rich and the other better but not enough i will also put a o2 sensor on it when i get time do i hve to wire up the heating side of it or will it work with out also is the heat on all the time the cars running and what are the advantages of a o2 sensor also im not running. also am i right in thinking the 1800 zetec injectors are 180cc min.
MR ZEFECT
saqmaster
Post by saqmaster »
Zetec 1800/2000 injectors are typically in the 170cc/min @ 2.7 bar region. You're really pissing in the wind trying to map a car without some way of monitoring the air:fuel ratio (eg, wide band lambda or a pseudo-wideband like a bosch lsu4)..
