Any opinions on a 500 hp Turbocharged Hayabusa. I'm using a MSII with MSD MC-4 for Ignition.
Size = 1298 cc's
Torque = 230lbs.
HP = 450-500
RPM = 11,000
AFR = 12:1
Thanks.
Can you be more specific? Are you looking for a baseline table to start from or?2WHEELENGR wrote:Help with VE Table.
Nope I am running MS on a Turbo Busa too, but its in a carboosted2000 wrote:Three of us are building Busa dragbikes, all MSII and all MC4 for spark. None of us are shooting for 500, but my friend has all the good stuff in the motor and may make a run at the low 7s maybe sixesI would be happy with 8.20s. We are all running Turbonetics t3/t4 turbo, 650 RC injectors, Tial WG, Tial BOV, etc. We plan to fire them up in the next 3-4 weeks. May have something then, or a pile of parts after the dyno session
Good Luck, I thought that we were the only ones running the MS on a turbo-Busa.
Jocko
The MC4 is awsome for drag racing. It has 2 step, autoshift, timing retard under boost, launch timing retard, individual cylinder timing, etc. etc. Everything is laptop controlled and you a lot of flexability with the different controls.bazzer wrote:oops I just read you are using an MC4 for spark.
Why not go Megaquirt I and run extra code and use that for spark ?
Cheers
Bazzer
