Nissan Primera
Cooke
Nissan Primera
Post by Cooke »
I am looking at all different types of ECU for my car but i need to clear a few things up first.
1. Is the MegaSquirt2 a stand alone ECU (i can throw my Nissan ECU away) of simply a piggy back unit?
2. I would like to be able to adjust the advance and retard on the ignition (possibly have two tunes - one with and one without nitrous).
3. The Dizzy is a lucas unit, would this cause any problems?
barf
Post by barf »
re 1 & 2. its a standalone/complete fuel injection and spark control unit.
to answer 3; almost any dizzy should work fine. where you might encounter difficulty is getting an RPM signal into the MS
is it an SR20DE engine?
it's not the size, it's what you do with it.
Cooke
Post by Cooke »
yeah a UK spec SR20DE (with a RNN14/GTi-R head to be fitted).
Cooke
Post by Cooke »
Also, is there anyway i can use a MAF sensor rather than the MAP sensor?
Mike_Robert
Post by Mike_Robert »
There have been a couple of people using Ford MAFs for special projects where SD won't work due to no vac signal - JetSki/personal watercraft for one. The Extra code does support these. If you're thinking of using the Nissan unit, it's probably a no-go at this point. A lot of the non-Ford MAFs use PWM duty cycle or frequency as the flow signal and MS cannot decode these. Also hard to find on the non-Ford MAFs is info on their transfer functions. There is no reason you can't make speed-density work just fine.
-Mike
Cooke
Post by Cooke »
how hard is it to switch to a MAP sensor? Drill a hole in the inlet manifold, and stick a pipe in to the hole, and attach the other end of the pipe to sensor - bobs your uncle fannys you aunt?
nismoryco
Post by nismoryco »
Jim Wolf Technology in the US often uses Ford Cobra MAF sensors as an upgrade path to the standard Nissan unit. They might output very similar signals. And as far as speed density goes, you just need to run a vacuum hose to the Megasquirt unit.
Cooke wrote:how hard is it to switch to a MAP sensor? Drill a hole in the inlet manifold, and stick a pipe in to the hole, and attach the other end of the pipe to sensor - bobs your uncle fannys you aunt?
That's it. Although you probably have a hole you can use somewhere, and of course much of the "pipe" will be flexible tubing.
