megatune issue please offer some advice
nitrostamped
Post by nitrostamped »
hello i'm building my v3.0 blue board with a msII setup I jumped and dl monitor_v2.35 to the board with no issues I'm just having trouble getting mega tune to work i get a common error
"controller code version does not mach signature in megasquirt-.ini (see audit.log for where the abov file was found.
expected "0x14"(found in ini file)
received "msII rev 2.30000 (from controller)
table corruption may occur... ... ..."
how to I ajust this i tried to activate 2.3x and save but nothing happend please help this newb
Tadek
Post by Tadek »
Have you renamed the MegaSquirt-II.ini.2.3 to MegaSquirt-II.ini in your MegaTune\mtCfg folder?
If not, do this. Then your MT version should match the firmware version that you uploaded to MS-II (which is 2.35 as you stated).
Cheers,
Tadek
bstruble
Post by bstruble »
I have seen this happen when the communications parameters were set for for msi and msii processor was being used. IE 9600 instead of 115200 -- also have seen this when when msi was "set" when msii should have been. Check your software setup for megatune.
herkamer
Post by herkamer »
http://www.megasquirt.info/connect.htm
Start at step 5 to load the code and activate the proper .ini file. That should get you connected and running.
Matt
80 Mustang Notch, 2.3T EFI, V3 MS2, 2.36FW, TFI, PWM IAC
Coming soon: 69 Dart Swinger 340, A500 OD MS2...hoping for 500hp!
