IAC tuning. Am I crazy? (Solved!)
bluetrepidation
- Experienced Squirter
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
bluetrepidation
A.J.
V3 PCB
MegaTune 2.25
Philip Lochner
I'm following this topic with great interest. All 3 diagrams seem the same to me. Am I crazy?bluetrepidation wrote:Alright I busted out the scope. Well as you can see looks like I have a blown driver transistor! Agree?
A.J.
Is it the kink in the green trace which you interpret as the blown tranny? Were you using balanced probes? I have an old dual channel scope but I'm reluctant to connect up both channels simultaneously as I'm worried that the earth leads on the two channels may have a common ground and then short out something.
My IAC seems to be working OK now except that now and then it seems to stick in the open position (when engine is cold) causing 2000rpm idle. Driving 2km's and then restarting sorts idle out - still a nuisance though.
Philip
bluetrepidation
A.J.
V3 PCB
MegaTune 2.25
Cool pics. Looks like whats happening is when 2A goes high it's shutting off output 1 until 1A goes high (it's half stepping). Goto http://www.allegromicro.com/sf/2916/, you can download the 2916 datasheet and also the Techincal Publication "UDN2916 Current Ratio/Timing Diagrams" these will help you understand the 2916. What I would check next (if I had my new scope) are the "I" inputs, these are used to change the current limit and turn off the outputs for half stepping.
These four inputs should be low (0 Volts) for normal operation. Check pins 1, 2, 12, & 13 with your scope with the IAC motor running.
Also, changed the components on another MSII last night, the IAC seemed to work good on the STIM, haven't had a report on how it works in the car yet, Will report later.
Scott
bluetrepidation
Alright I'll keep things posted.
A.J.
V3 PCB
MegaTune 2.25
bluetrepidation
A.J.
JSC wrote:A.J.
Scott
V3 PCB
MegaTune 2.25
Sounds like the "I" inputs are functioning properly, I'm still curious as to why your output is half stepping (would like to check mine but the new scope won't deliver until Wed.). Are you going to change your 2916? Either way, I would change the RC components, the two I have changed work much better, but I don't think they're 100% yet. Maybe change the RC components first, recheck the output, if it's still half stepping then consider changing the 2916.
I would like to check the output on some more 2916 drivers before assuming that yours might be bad. Another test I would do is scope the phase inputs to the 2916 while it's running. If you keep doing all the tests, I won't need a new scope.
Scott
bluetrepidation
bluetrepidation
