Autotune question
Karl
Autotune question
I have run autotune with a narrow band sensor, so I know a little bit about how it works. Inderstand changing the .ini file for boost/vacuum and RPMs, but how do I adjust for the desired air fuel ratio I want? I have megatune 2.25 and MSnS 024s. Do I just change the EGO switch point voltage under EGO control to what ever ratio I want autotune to tune to? Also the AFR targest for VE table button is greyed out on my megatune. How can I use this?
Karl
