Fuel Tank Construction
eliotmansfield
I need to make a new fuel tank, 15 gallons. I've spent ages searching the net for any information about what spec ally, design ideas and how thick to make it.
Â
It will be made from Aluminium, I'm thinking 1050 grade and 14 Gauge thick - I'm going for the that thickness because I cant roll any swages into thinner material to provide strength.
Â
I've got a cardboard mock-up that I can post a picture of, if anyone fancies giving a critique.
Â
Eliot
Posted by email.
eliotmansfield
My tank...
flyguyeddy
eliotmansfield
bertelli_1
Just a untested idea..
78Spit1500Fed
- Site Admin
HA HAAA!!!!bertelli_1 wrote:I'd stick with a cardboard one. Apparently that ally doesn't half buckle when YOU try and weld it.....
Ah, the art of aluminum welding. I have yet to master Steel MIG welding, I think I'll go straight to TIG when I venture there.
Elliot, that tank design looks good... is that piece out the bottom the sump? If this is going in a 4x4 you might consider a hinged pickup arrangement (Or a weighted hose) that will move with the fuel as you go more or less Horizontal.
-Brian
eliotmansfield
Had a complete nightmare trying to TIG this thing up, the ally warps like crazy.
See http://www.mez.co.uk/ms13.html for the whole sorry tale.
