Shift light with MSII ?
Clifton
Post by Clifton »
Is it possible with MSII, I know it is with MSI.
bluetrepidation
Post by bluetrepidation »
You could prob set a general output to come on at low MAP and HIGH RPM indicating to shift. Though when you are in 5th gear it'll lit anyhow because there wouldn't be a input for that. I was thinking of doing this myself since my car has an up shift light. But who needs these amenities when you can tune your ECU. :twisted:
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
Clifton,
Yes, you can use the spare outputs to configure the LEDs to do this.
For example, you can set:
- PM3 - Injection LED,
- rpm > 4500,
- hysteresis = 0 ,
- power on = 0,
- trigger = 1
- PM5 - Warmup LED,
- rpm > 5000,
- hysteresis = 0 ,
- power on = 0,
- trigger = 1
- PM4 - Accel LED,
- rpm > 5500,
- hysteresis = 0 ,
- power on = 0,
- trigger = 1
This will light the LED (which could be mounted remotely) from left to right as your rpm rises. You can also use different color LEDs for each rpm, to provide a more striking visual clue.
zguy360
Post by zguy360 »
I gutted my proform shift ("crap") light and hooked it up to one of the spare outputs. I simply used the transistor inside of the shift light to handle the higher voltage and triggered it with one of the spare outputs, one of the ilde control outputs I think. Works great, and I am using MSII V3 board.
User avatar
460stang
Post by 460stang »
I am using PWM idle so my IAC outputs were free. I am using one to fire my autometer mini shift light directly. Works well with the spare output settings.
Clifton
Post by Clifton »
Thanks guys.
Clifton
Post by Clifton »
lance wrote:Clifton,
- rpm > 4500,
- hysteresis = 0 ,
- power on = 0,
- trigger = 1
- PM5 - Warmup LED,
- rpm > 5000,
- hysteresis = 0 ,
- power on = 0,
- trigger = 1
- PM4 - Accel LED,
- rpm > 5500,
- hysteresis = 0 ,
- power on = 0,
- trigger = 1
Would these be the 3 LED's on the board? If not what pin number would they be? I'm just wiring everything now and want to add whatever I need to the DB37 plug for later.
Clifton,
Yes, my example was for the three LEDs on the main board.
