Idle issues
scirocco_per
Idle issues
I have build a engine 1900cc, eaton M45 superchager, ic and megasquirt (fuel and spark) and my problem is my idle is 1500rpm if I lower it is jumping 800-1300rpm.
I have try to seek vacuum leeks and look in the fuel tabels for diffrents in the idle area but nothing.
http://www.scirocco53.net
MS-I/MSnS-E V3
The EGO Sensor will cause ocillations if it is operating at low speeds and is
capable of making large changes to the AFR .
It should be set to operate only above ~1500 rpm ,
and the "authority" should be 5% to 3% .
Also , check your injector pulse width at idle ,
if it is less than 1.5 ms it may cause idle instability .
Let me know what you find .
...................Jim
bertelli_1
scirocco_per
http://www.msefi.com/viewtopic.php?t=19053
MSnS-E V3.0 code Extra 029q2 Edis4
scirocco_per
http://www.scirocco53.net/download/data ... 222017.xls
http://www.scirocco53.net/download/data ... 222021.xls
I have seek vacum leaks but nothing
MS-I/MSnS-E V3 029q2 code and PWM valve
scirocco_per
Giv me more clue!
/Per
mops
- Experienced Squirter
