O2 ehaust settings. can someone help please
casper002
Post by casper002 »
Hi people...
i just want a little help with a few settings in the below info,
I think once i can get thigs sorted here it might make it a bit better for me.
I do think i am getting there but by hell i didnt think it would be this hard
what is best to put in the boxes in there
like
change ego limit above(kpa) ?????
change ego limit to (+-) ?????
i think for ve table 1 should be ON
ve table 3 off
speed dencity
and use targets = always
Now then can you help me in here too...
in the exhaust gass settings too
like whats best to do in here
like
EGO sensor type = wideband i am using the lc-1
EGO switch point (v) ???? i think its got to be 2.5
ignition events per step ????
controller step size (%) ????
controller authority +-(%) ???
active above temp ???
active above rpm ???
can anyone give me some advice on this or the default settings for a wideband setup
thanx again
davey
User avatar
fastereddie1011
Re: O2 ehaust settings. can someone help please
Post by fastereddie1011 »
Thats my settings and they work pretty good. Make sure you setup for the innovate 0-5v 10-20afr in your mt config and program your lc-1 with lm programmer.
My drinking team has a racing problem!
1989 ford probe lx. Turbo Fe3 swap
Approx. 300hp courtesy of Msns-extra
casper002
Post by casper002 »
Thats strange fastereddie..
your saying that thats your settings and they work ok...???????
i am asking for assistance in what i should put for my settings, and i havent given many of my settings that would make any engine work fine..
i think you may have miss under stood my post..
i am needing some one to give me an idea on what i realy need to put in the boxes.
thanx anyway..
davey
Jedrik
Post by Jedrik »
There is really no "best" value. Otherwise they would be programed in and not adjustable.
Some of the settings, like ignition events per step depend a bit on what RPM you are running and how long your exhaust is before the EGO probe.
I don't remember MSI well enough to give consise settings for you.
But I would start with the defaults and read up about Wideband in the MegaSquirt tuneing instructions. Then if you find issues you can tweek settings.
For LC1 using 10-20 afr gives AFR of 14.7 at 2.35 volts.
That would be your crossover point... unless you are using AFR target table then it is irelivent (If I am remembering msns-extra wrong, please correct me)
I calculate the target voltage like this:
.5 volts * ( AFR - 10) = Target voltage
