Good, then you have a fuel pressure guage and are ahead of most on that reguard.fuel pressure kept going to 0 and back to 42 while t
Dataloging is easy, and somthing you will want to do everry single time you run... at least for a while.
I've been runing for... few thousand miles now and still like to log just to see how its working and kep refining the tune the last little bit.
In megatune go to File:DataLogging:Record or press Alt-L
when you are done running you go the same plase to stop the log.
Then you want to look at the file with MegaLog Viewer.
This will really help you (and us) see what is going on.
But you will deffinately have to sort out the wacky fuel pressure and CLT issue.
Good luck with the adventure in Moving. Ick!
