The cylinders are flooding on turnover
ClassicFordsdotnet
I've read that the 803 injectors flow at 330cc/min or 382 depending on where you read it, it was set at 330 so I swapped to 382 and went for a drive. The engine flooded after 50 feet. I've changed the setting back, and I just can't get it started. The cylinders are just getting full of fuel.
I took the plugs out, and turned the ignition on (I've set the fuel pump to pump when the ignition is on, rather than when it's cranking) and I could see fuel being pumped into a couple of the cylinders. I disconnected the power wire to the injectors and looked, and it had stopped. This, to me, says the injector isn't stuck open.
When the engine isn't turning over, but the fuel pump is running, shouldn't all the injectors be closed?
Has anyone come across this kind of thing before?
And does anyone know for sure the flow rate for an 803 injector?
Cheers
(Moderators:I've posted this in the european forum, so feel free to remove it from there, as I think I'll get a better response in this forum)
jsmcortina
- MegaSquirt Guru
Those injectors are low-z aren't they - as such you need to setup injector PWM and ensure you have the hardware for active flyback protection. On the v2.2 board this requires a second board, on the V3 it requires that all the parts be installed (they usually are.)
Either way, strip the Megasquirt and check for burned injector drive components.
ClassicFordsdotnet
Looking at the board, it looks like the q1/tip42 transistor has fried. Now, how do I go about fixing it as I didn't build the 'squirt in the first place. Is there anyone in the UK who can supply the necessary components, or one fully built? Reason for the urgency is I'm going on holiday on Wednesday, and I'm needing the car running for a show I'm going to a couple of days after I get back! (It's the Classic Ford show at Santa Pod. You may be there, James, if you've got a Cortina!)
jsmcortina
- MegaSquirt Guru
Bill Shurvinton or Phil Ringwood are worth contacting for a flyback board and a repair while you are away.
I could repair it and likely source resistors, but don't have a flyback board.
ClassicFordsdotnet
I found a post on the UK Megasquirt yahoo group with a link to someone in the UK supplying boards (http://www.americanv8engines.co.uk/shop ... cts_id=194)
so hopefully either one may be able to sort me out.
Cheers
ClassicFordsdotnet
jsmcortina
- MegaSquirt Guru
