multiport injector mounting angle???
car is a 1.8L turbo honda.
sooooon to be squirting!
lani16
65ShelbyClone
You can mount them vertically, but that is far from ideal. Ideal is to have the injector spray the backside of the valve head. It also depends on the spray pattern; some have a pencil point spray that will splatter on the runner wall and others have a foggy fan spray that will get caught in the intake air more easily.[/list]
'84 Mustang SVO - E6 manifold, wet cartridge T3.
1.6L bored and stroked to 1.8L
ported / polished head
polished pistons
blueprinted and balanced rotating assembly
12lb flywheel
turbo cam grind
kevlar clutch
t3-turbo
lots of msd stuff
pressurized weber carb (now removed for efi)
new injection system:
ms v3 board + relay kit
wideband o2 sensor
removing msd stuff (boost retard etc)
4-450cc injectors
acura vigor throttle body
i'm converting to efi cause its just to hard to make the carb run well under all circumstances. i run it rich, very rich and boy does it go at 9lbs boost. but its waaaaay to rich-idling, cruizing, everything but boost. so here we go! as soon as my injector bungs show up.
from what i read here it looks like i'll stick the injectors close to the head and at as much angle as i can get without interfering with my throttle body. it is reasuring to hear it should run OK with the injectors vertical. but i will try to angle them as much as possible. i hope the injectors are a spray type pattern rather than a stream.
65ShelbyClone
Carbs do tend to run a little rich off-boost, but I know nothing about tuning a Weber for blow-through. Holleys on the other hand are more widely used for this and you can get 4 barrels down to 390cfm which would work for a 1.8L. Just FYI. You already have the MS and it will be more efficient.
I would at least consider a sheetmetal EFI intake, though.
