Megasquirt No Throttle - Lean (decel)
From conversations with others I've gathered that most factory cars and aftermarket standalone fuel injection systems essentially shut off injectors on deceleration.
Is this true? From what I've seen megasquirt does not reduce fuel supply on deceleration (triggered by MAP, RPM, or TPS) with the exception of TPSDQ(Decel fuel amount %). It sounds like to duplicate this decel - lean condition we have to setup our tables to do so. Is there any reason to aside from fuel savings?
Reason I ask is that from idle when letting off the throttle my AFR increases, sometimes to full lean. I attached a data log and .msg file. (i've got other issues, unstable idle to deal with as well).
MS II V.3.0
I've been using the over-run fuel cut of MSnS-Extra to do exactly this. I set the settings so that anything almost 0 throttle and fairly low map cut the fuel after 0.1seconds. This was the only way i could stop it hanging at high idle when running as piggyback. Saves a fair amount of fuel too lol.
J
Datalogs and current MSQ - http://www.jbuckle.homeip.net/datalogs
