Fighting vacuum on throttle opening / Mustang TB
Question:
I've bolted a supercharger on to my volvo B20 and I'm using megasquirt to fuel it. It's working great. This is a general question about the throttlebody setup I'm using.
With the supercharger I used a 55mm OEM throttlebody from a 90's ford mustang with the IAC housing flange blocked off. Pictured here:
http://pics.1800philes.com/supercharger ... C_0004.JPG
Since the ford idle controller stuff doesn't fit (I tried!) I just use the gas pedal to do a fast idle for the first 20 seconds and then the motor warms up and runs fine. I adjust the motor's idle by cracking the throttle open a little bit with the adjustment stop.
When the engine is off everything works great - no binding of the throttle cable, spring tension is perfect - pedal feels really good. When I'm driving , however, I am always fighting to modulate the initial throttle opening. As I go to depress the pedal I am initially fighting the engine vacuum to crack the throttle plate - and then it reaches a tipping point where it opens quickly and easily. The net result is a jerky throttle that makes smooth street really difficult.
I'm scratching my head as to how to smooth this out. The OEM setup was a similar diameter throttle plate and this was never an issue. Anyone run into this before? I feel like I am overlooking something obvious.
steve berry
http://1800philes.com
greggearhead
Pays to ask questions. I'll post back here if it works out.
Thanks!
steve berry
It made my car go a lot faster. Tried it out at autocross today - did worse in the pack than I normally do(!). It's all about smooth transitions - a jerky throttle doesn't sent me all over the course. Trying a stiffere return spring setup tomorrow.
steve
TPI 85 Blazer
You can check for throttle linkage geometry problems by directly operating the throttle body by hand while idling. If it operates as easily as when not running it's a throttle linkage geometry or binding issue. If it's harder to operate directly by hand at idle with the linkage disconnected, then I would consider the internal binding as TPI 85 Blazer suggested.
You may be able to identify internal binding by pressing the throttle shaft (not blade) firmly inward (simulating a max vacuum load on the plate of around 20kg/45lb) to see and feel any changes.
HTH,
David
Car Dyno'd at 155whp today with a big usable 151 lbs of toque on 10psi. Pretty stoked.
http://1800philes.com/supercharged_volvo.html
