attached is a spreadsheet i made using some assumptions and calculations from lance. below is a short description.
the benefit of this is you and play with a timing curve to see what effects like fuel octane would have on a timing table.
The first page establishes the assumptions based on motor, bore, fuel, cyl head and then inputs the 100 KPA values. The remaining is the boosted vs na and each cell is calculated from your formula by the 100 KPA advance and the KPA. Note, afar from discrepancies from the fact ms excel 2003 only has 3 conditional formats, it is quite flexible. if one should change the KPA settings, it will update that entire row, same if they change the ignition from premium gas to regular for example.
On the boosted portion, the calculations don't adjust for ensuring the value is no more than half the 100 KPA Timing.
as time permits i will try to add some if/else statements for the boosted portion of spreadsheet but no deadlines as to when i'll have that done. of course, anyone is welcome to modify the calculations to their needs.
btw, i made this in 2003, i believe it should be backwards compatible but with microsoft who knows?
If you have questions or comments send me a message on the forum.
for more info on lance's post regarding the calculations and assumptions see: http://www.msefi.com/viewtopic.php?t=9941
