fuel presure problems
The problem we where having is when the fuel pump comes on (new walbro inline 255) with the engine off it goes up to the 42# that we want, but then after about 4-5 seconds the pressure drops down to 20 or less and then bonces around about 10#.
It does the same thing with the car running(well hardly running) with or without the vacume refrence line connected.
And while running if you tap the gas the pressure will go all the way down to almost 0.
As of now I am betting it is a bad pump. It is slightly lounder than my 255 inline and he did run the tank dry here recently, but it does have a large inline filter before the pump also.
Also everybody...Tell him not to give up on this car. He is so close to having a damn quick little street car. It's a built bottom end (eagle rods, wisecos) He has a nice cam, about the best head you can get, a good size turbo and a EFI that is pretty much ready to go.
I even have an extra inline 255 and regulator that he can barrow!!
Here is the car in question
Car starts and idles with megasquirt and EDIS with 750cc injectors
It's just a few small glitches away from being done.
Idle video!!
http://www.eville140.com/3tstarlet/l.wmv
Later
Randy
If it still acts the same, pull the fuel line before the rail to check free flow volume for the same dropoff. If it does drop volume after the 4-5 seconds, try pulling the Out line off the pre-filter and do a quick flow test by pressurizing the tank to a couple pounds (careful!) to test free pickup, screen, and filter flow that may be cavitating the pump. I just wrap a shop towel around the air nozzle and shove it in the filler neck and give it a squirt of air. Just enough to check for free flow - don't balloon the tank! It just beats sucking on the fuel line...
If you have the spare pump to drop in at any time then start there, but if it acts the same, the diagnostic flow tests may show you where the problem lies.
David
