tuning turbocharged ITBs? anyone?
Here is the trick This is for a turboed engine. I have made a plenum box with vstacks inside that hpefully will distribute air evenly at most RPM/Pressure, I have had some guidance making this from others on this forum, but does anybody have any tuning experience with this kind of setup?
75 Cosworth Vega turbo (MSII with EDIS)
88 Toyota Pickup, Auto(modified valve body), 22re 4cyl, controlling fuel and VAST stock ignitor with MSnS 024s9
1968 Electric Subaru Sambar 360 VAN
'92 Biodiesel Jetta
I used speed density algorithm without any problems when the engine was NA. I was able to tune it just fine, also for idle. But with turbo I faced some problems. I tend to get way too high MAP values (like 100-110kPa) when cruising at steady speed and low throtle opening. I guess that the reason for this is increased exhaust backpressure combined with quite big overlap. Anyway, it made tuning very difficult, it was impossible to tune it for both cruising and acceleration.
So I switched to hybrid alpha-N and it seems to work much better. I haven't tuned it completely yet but at least I can tune it for all situations now. Only drawback is ignition control. It isn't so handy to define engine load by TPS values with turbo.
Tony
'92 Biodiesel Jetta
Fastest95PGT
It had to be between the ITBs and the motor as you have it. Otherwise the motor would never read vacuum so you'd have a hard time driving it that way.ArttuH wrote:The MAP is connected to the runner side, between throttle plates and the engine. I think this gives better resolution for low throttle openings.
2003 GSX1300R (Hayabusa)
I have drilled and tapped my runners for NPT fittings, and plan to run them to a common plenum that I am planning on using for both MAP and Vacuum boosted brakes???. My mistake is that I tapped the bottom of the runners, not realizing at the time that my secondary injectors are going to be shooting right at them, now I am worried about my common vacuum rail filling up with fuel.--Whoops!!! I just hope I have enough vacuum volume/speed to operate the brakes, because of the small holes in the 4 barb fittings (3/8) that are tapped into the runners.
'92 Biodiesel Jetta
