mass air flow??? w/wideband lc-1 on a turbo 2 stroke?
bansheeboy420
I've been planning to build a turbo banshee for a long while now. and when I first put it to my bro. who is a strait up geneous with anything with an engine. He told me to wait for microsquirt. So... I started reading and gathering info about what I need. "whittlebeast" has helped me a few times already with which maf to get. And also to go HUGE on the injectors. Like 25lbs primarys and 55lbs secondaries (turbo) which is more than I need for gas, but I might be going to a 10% nitro/alcohol mix. Which I might even have to go bigger than that.
Question#1> Why is their a boost limitation of 20lbs.? Can a new code be written so I can run upwards of 30+lbs.? Because the turbo I'm using is most efficient at around 2>2.5 bar (roughly 25-36lbs)
Question#2> Can somebody send me a rough wiring dia. for a ste-up like this one? (windband o2(lc-1) / maf(ford) / tps ect.
Question#3> Will micro be able to do what I'm asking? aka 2 sets of injectors and all the above...(high boost)
Question#4> What else do I need to know/need to get moving on this before the micro is out?
chicksdigwagons
Re: mass air flow??? w/wideband lc-1 on a turbo 2 stroke?
#1 The only limitation you'd have on boost is what the MAP sensor is capable of. The normally used megasquirt sensor is good for 250kpa, or roughly 21psi, you can also use a 300kpa or 400kpa sensor instead with little difficulty so you're good up to about 56psi. Microsquirt uses an external MAP and I'm not familiar with what is available but I can assure you that doing over 20psi will be no problem.bansheeboy420 wrote: Question#1> Why is their a boost limitation of 20lbs.? Can a new code be written so I can run upwards of 30+lbs.? Because the turbo I'm using is most efficient at around 2>2.5 bar (roughly 25-36lbs)
#2 Can't help you there, but if your brother is at all comfortable with electronics this should be a peice of cake.
#3/4 Microsquirt will work out fine for your application. However, in my opinion its not going to be worth the wait or price. While packaging is always a challenge with any powersport vehicle, I'd guess if I can find the room on my motorcycle you can spare the room to mount a full-size megasquirt on your quad.
In any case, good luck with your project. I'm really curious as to how long you can keep that motor together at 25+ PSI. I've done some research into turbo-two strokes in the past in the interest of my snowmobiles and they seem in general to be a finicky bunch! I look forward to seeing the results!
bansheeboy420
whittlebeast
AW
Matt Bonhage
