Datalog target afr
Datalog target afr
Does anyone know if there is an easy way of datalogging target afr. I'd really like to see it in MegaLogViewer just below the real afr...
Cheers
Dave
Add the line:
Code: Select all
entry = afrtgt1, "AFRtrgt1", float, "%.2f"This may give you values that are 100 times to large (ex, 1370 instead of 13.7) - if so, find a line in the same file like:
Code: Select all
afr1 = scalar, S16, 28, "AFR", 10.00, 0.0Code: Select all
afr1 = scalar, S16, 28, "AFR", 0.100, 0.0Lance.
You probably didn't modify the ini file that Megasquirt is using. If oyu look for the audit.log file (makes sure it is dated the same as the last time you openend MegaTune) you'l see all the files and directories MegaTune used to open. Look for lines like:
Code: Select all
r MegaSquirt-II.ini
+ C:/Program Files/MegaSquirt/MS2_v2.8/mtCfg/MegaSquirt-II.ini
MegaSquirt-II.ini:0102 #if LAMBDA, including=false
