edis question 2
edis question 2
is it possible to use 8 coils on a edis 8 module?
I'm askin this becouse i dont want anny sparkplug wires going acros the engine so i can mount 8 small coils on the inner fenders and still use wasted spark.
thanks
MSII V3 code 2.25
I've been running an 8 COP EDIS-8 setup (waste spark) for quite a while now with no problems, and the car runs extremely well. You'll want to wire the pairs of coils in series.
Justin
My Success Story: http://www.msefi.com/viewtopic.php?t=11602
Can I ask what car your COP's came off of?Turbo4V wrote:If you do a search on EDIS COP (coil on plug), you'll find a bunch of info related to EDIS, Waste spark, and COP's (or 8 coils as you're referrring to them).
Justin
allen
The COPs came off of a 2003 Ford Mustang Cobra, they were actually specific to the valve covers that I was using.
Justin
Justin
EDIS can only drive the +12v/GND style coils, not the logic level, 3wire style.
Justin
allen22 wrote:Thanks,
I think that's the general rule for an EDIS COP install, must be 2 wire instead of 3 wire.
Fred
edis question 2
Just figuring out to wire them up, can't be that hard to do huh.
Main problem to find COP's, i live in Belgium and these are realy hard to find here.
MSII V3 code 2.25
+12v switched -> coil 1 +
coil 1 - -> coil 6 +
coil 6 - -> EDIS Channel 1
And so on for each of the cylinder pairs. (1&6, 3&5, 7&4, 2&8 )
Your firing order might be different, so you'd combine differnent pairs.
Justin
