E85 Question?
2001dodgeneonrt
E85 Question?
My Success Story...
Okay, I think I just made the confusion worse...
2001dodgeneonrt
My Success Story...
Ethanol, Gasoline, or any mix of the two, while running at stoich (for the fuel) will cause an O2 sensor to read lambda = 1
That said, if you are at 11.5:1 AFR and its good to go, that meand you are running at lambda = .78, about 22% rich. This means your E85 should also be set up 22% rich, or lambda .78. For E85 however, the AFR will be about 7.7:1
One other point of contention:
If you are running so rich for the fuel intercooling affect (which is to say that you are knock limited by lean mixtures), you will be able to run considerably leaner with the E85, and thus, pick up power and better fuel consumption.
HTH
2001dodgeneonrt
My Success Story...
2001dodgeneonrt
Who is online
Users browsing this forum: Amazon [Bot], Bing [Bot] and 14 guests
