No PWM during cranking?
Philip Lochner
1) Is this correct?
2) Should it be so?
Philip
Mike_Robert
Yes, that's right. The duty cycle is very low, so there's no chance of overheating the injectors, and the voltage drop while cranking can be quite signficant, often to less than 10 Volts. Eliminating the the PWM during cranking allows the running PWM% to be lowered quite a bit, and overall makes the injectors run much cooler.
Al made this change in the late stages of the MS-I code, I recall, and it has been carried forward into everything since then.
Philip Lochner
Excellent! Thanks for the confirmation. It helps for that first time you turn the key after having wired up the injectors and the adrenalin is running in overboost.... If I destroy this V12, I might as well throw the car away.Lance wrote:
Yes, that's right.
Philip
Philip Lochner
I realised last night that I WILL therefore have to install resistors (or use the existing). If there is no PWM during cranking, with 6 x 2.5Ohm inj per bank, that could total 24A (@ 10 V) during cranking. MS limits current to 14A.Mike_Robert wrote:I'm pretty sure it's that way [no PWM during cranking] by design.
This might explain why instead of hearing the regular tick tick tick when cranking, I heard "crrrrrr". I am assuming this is due to current limit kicking in and out.
Philip
