Nice work!
Can I ask what software you used to generate the Alfa-N map?
I've not managed to get one out of MSTweak3000 or VexMe.
Paul.
It's an application I wrote when I was investigating the relative merits between SD & Hybrid Alpha-n with my ITB setup. I uses the vex files for the current VE and AFR tables and outputs the files I posted and updated vex files. It is still in a crude form, I've not had chance to make it suitable for general use yet. It's written in C++ so is significantly quicker thanVexMe and performs extensive filtering to only use relevant data.ptownsin wrote:Colin,
Nice work!![]()
Paul.
Hi Colin,Cairb wrote:Chris,
I've had a quick look and have the following observations:
From the O2 readings it looks like your useing wideband, is that correct?
If running wideband with 0v = 10/1 and 5v = 20/1 then it looks like your experiencing the usual steep rise in VE with MAP above 90kpa. as it looks like your running rich at 90 and about stoic at 97 where I think you should be closer to 12.5.
If you've just used autotune then it may be that you have too few bins around this non linear region causing this.
With this configuration some consider placing more bins in the 90-100kpa range but I have found that Alpha-n gives better control at full bore which would imagine your wanting.
Search some of my previous posts for details if relevant.
I have run your datalog through my analysis software and attached some xls files based on SD and hybrid Alpha-n file based on a variable AFR table running about 16/1 at light load and 12.5 at full load. The zero's are missing elements are where there were no data points so would need.
I'm running a 2.3 Duratec on ITB's and noticed a significant improvement on Alpha-n as have a few others.
PS which version of megatune are you using as I couldn't load the msq?
Cheers,
Colin
