Building your own fuel rail
sidy
I am looking for some guidance from the group on this questions.. Is
it realistic to construct my own fuel rails (for 4 cyclinder
motorcycles) from soldered coper tubing or is it better to buy an
aftermarket assembly?
Sid Young
Visit Sid's
"Classic Japanese Motorcycle Restoration Site"
http://z900.piczo.com/
Posted by email.
jakobsladderz
I guess I'm saying that steel tubing may be a better bet to avoid the chance of fatigue cracks and subsequent fuel leakage.
Duncan
Steel tubing can be had in a nearly perfect I.D. for injectors and be brazed as many factory rails are. I have scavenged injector cups from brazed OEM rails like this. Once again the brazing is fatigue prone so support it - and the brazing itself makes the steel more brittle over time to a limited degree. This is why aircraft manufacturers no longer assemble steel fuselage sections with brazing.
It's a balance of your skills and your wallet.
David
It's been used for abt a year , then I changed it for an extruded aluminium one .
Not because it failed or leaked , but because it didn't look nice .
There must be some pictures of it in the succes stories .
As long as it's decently secured to the engine block , there's no problem .
Pat
jsmcortina
- MegaSquirt Guru
TT350chevelle
http://public.fotki.com/tt350chevelle/6 ... 10002.html
Brad J.
sidy
I can anodise it red so it looks fast also ;)
Sid
PS - Hadn't thought of Aluminium, real asy to work with and easy to
get and to machine any unique fittings...Thanks James
On 7/17/06, jsmcortina <jsm@jsm-net.demon.co.uk> wrote:
> Mine are sections of steel tube brazed together. However the aluminium
> extrusions will be easier to work with and look prettier afterwards.
> James
> ________________________________
> My Success story http://www.msefi.com/viewtopic.php?t=8008
> MS1/Extra at: http://megasquirt.sourceforge.net/extra
> This post is at:
> http://www.msefi.com/viewtopic.php?p=130963#130963
Visit Sid's
Posted by email.
What is 'braze 380' ?TT350chevelle wrote:Square steel tubing, 1/2 compression fittings and braze 380.Easy,clean and cheap.Heres the only pic I have of my fuel rails.
Brad J.
TT350chevelle
Here's the link to Braze 380 pdf file.garrymc wrote:What is 'braze 380' ?TT350chevelle wrote:Square steel tubing, 1/2 compression fittings and braze 380.Easy,clean and cheap.Heres the only pic I have of my fuel rails.
Brad J.
http://www.lucasmilhaupt.com/assets/bra ... /BR380.pdf
and another link with info on a number of brazing products.
http://www.lucasmilhaupt.com/htmdocs/br ... _free.html
Brad J.
Who is online
Users browsing this forum: Baidu [Spider] and 16 guests
