Rough idle when warm.....!?
GS1100Norway
Solved with air leak fix.
Post by GS1100Norway »
I had the same problem with my bike in the beginning, and the real problem was air leak/"false" air in the inlet tubes.
I suggest that you should check for air leaks.
When the engine gets warm and the warm-up are shut of the engine gets more sensitive to air leaks. TRY IT !!
KnutK
quattrodave
Post by quattrodave »
Hiya,
Spent this weekend removing pipework and inspecting all rubber hoses plus all associated gaskets. No leaks found....
Despair beginning to set in now....
Dave
5 Cylinder 10 Valve Turbo :-D
keithmac
Post by keithmac »
Only thing I can suggest is an electrical component braking down when hot?
Can you warm the car up, pull the coolant plug off and fit a resistor with a value equal to the 50c region, would tell you if it`s a tuning problem or maybe a wiring/sensor fault somewhere?
Squirted VW GTI 16vG60 mk2
