Resonable EGO correction values w/ AFR targeting?
TurboCamaro
Post by TurboCamaro »
I'm running MSnS-E 25n9 code on a v2.2 board.
I finally got my VE table where I think I wanted/needed it. I decided to run full time wide band AFR targeting. I've seen EGO correction values as high as 105-107 and as low as 94-95.
Should I be shooting for numbers closer to 100 or are these pretty common on a well tuned VE table?
Also, what kind of +/- value is normal? I'm set to +/- 5 right now.
Also, on another note, is the reason the AFR targeting table is only 8x8 is because of a lack of available memory? It seems hard to get AFR where I'd want them when the AFR table doesn't have the same resolution as the VE table. Would it be of any advantage to make the AFR values added as an extra dimention on the VE table(a 12x12x2 matrix)? I guess the only thing you'd be saving would be the memory for extra bins on a totaly seperate table.
-Wayne
1994 3.4L V6 Camaro 5 spd.
Custom Turbocharged/Intercooled
itguy
Post by itguy »
Interesting- I'm getting the same with my VE map and EGO correction, seems to give me +/- 6 or 7%..
TurboCamaro
Yea. I also get 100 is some areas as well. I guess there are just some places in the map that don't match up. That's another thing w/ the lower resolution AFR map. When it interpolates btwn two extreams then it is expecting a AFR that I didn't tune my VE table to.
-Wayne
