Small fuel pumps
Small fuel pumps
Its looking like i'll use an R6 (or similar) pump, but most of those pumps are for 120+ hp.. I'm after one for about 25 hp!
Are any of the modern bike fuel pumps designed to run at under 12V? I was reading about a nissan that ran the pump from 8V to 12V (idle to redline). A 600cc pump at lower voltage might be better..
Any ideas welcome
andrew
I don't know sources for the little pumps (check here http://www.msefi.com/viewtopic.php?p=10 ... ump#107407), but I would think using the R6 pump would be better with PWM than reduced voltage. I would set it by energizing the injector(s) to 100%DC and turning up the pump PW until you just start getting bypass from the FPR. This should be good for establishing minimum flow and pressure at maximum demand to allow the least burden on the electrical system. Your falling voltage at idle may be your biggest obstacle.
BTW - what are you building? I have a tiny turbocharger for something in the 25-30 n/a base HP range...
David
A quick search found a zillion circuits for PWM but this link explains the benefits http://www.solorb.com/elect/solarcirc/pwm1/, while this one http://www.cpemma.co.uk/555pwm.html gives a detailed build of one that is cheap, simple and more than capable.
Perhaps others will provide other sources or circuits that you could use - but it's a start.
David
