Engine is hard to start
sindre
Post by sindre »
driving with MS-II v.3.0 on a audi 10v turbo ignition and fuel
when it's cold it starts okay, but when it's warm so that the cold start enrichments not is there I have to turn it a loty before it starts. Is there somwhere I can give it more fuel to start(cranking)?
I also have trouble with driving on cold engine, it wont have high rpm, so that I use verry long time to get to driving speed in the morning.
And one last question... When the turbo spins but the engine will not have it, shall I tune ignition advance up or down?
(i get pressure, but no accelleration....)
Audi 100 TQ 10v
tebriel
Post by tebriel »
do you have a wide band gauge to see what your fuel ratio is doing? those are all just tuning issues.
-teb
sindre
Post by sindre »
tebriel wrote:do you have a wide band gauge to see what your fuel ratio is doing? those are all just tuning issues.
-teb
So I have to do the warm start issue in VE? and yes I have WB.
Audi 100 TQ 10v
Check the cranking table and warmup enrichments. You can tweak the warm-up so it's still active on a hot day.
ae1969
Re: Engine is hard to start
Post by ae1969 »
sindre wrote:driving with MS-II v.3.0 on a audi 10v turbo ignition and fuel
- hard starting can be affected by Cranking RPM, After Start Enrichment, Cranking Pulse, Priming Pulse width, Warm Up enrichment. *** Read these areas again.
- cold engine with a low rpm - DO you run an idle stepper? If not you can play with timing, and fuel to compensate for this behavior.
- If turbo spins and engine will not have it. SOMETHING is not right. Carefull. You need a wideband and preferably and EGT if you want to tune by the seat of your pants. Generally ignition advance is pulled back as boost comes on.
944 2.5 L Turbo EDIS 4 MS2
My Success Story
tebriel
Post by tebriel »
can you explain what your wideband is saying during those moments of power loss? it's either too rich or too lean :)
sindre
Post by sindre »
thanks for all answers!
turbo spin but engine will not have it:
to much fuel in warm up...11 afr is to much :idea:
warm up and warm start:
what should be in "number of ignition cycles"? what does it do?
it's still hard to start when it is warm....
i do not have an idle stepper
Audi 100 TQ 10v
sindre
Post by sindre »
sindre wrote: what should be in "number of ignition cycles"? what does it do?
I repeat my self. default is 350 :|
Audi 100 TQ 10v
ae1969
Post by ae1969 »
can you post your msq file
My Success Story
