Home dyno?
rs2000
Post by rs2000 »
S.Bretz wrote:Your point of spinning tires and getting on over estimated out put is errelivant as that case would fall under the guides of "not using the tool properly."
Most cars where the owner cares about power will spin the wheels in second when you put your foot flat to the floor, even from a rolling start. If your foot isn't flat to the floor you aren't measuring maximum power.
You could do the run in 3rd or 4th, but then you've just introduced a far larger wind resistance (wind resistance is proportianal to V^2) and so will undershoot actual horsepower.
lemons
Post by lemons »
This isnt a way that will get you HP numbers, but the way i used to get my tune right on my honda was to make a pull in 3rd from 4k rpms till it hit the chip, then i'd see how long it took in the datalog to see if i was making a hp improvement.
Im sure theirs a way to calculate horsepower based on a rate of acceleration, combined with gear ratios and wind resistance and vehicle weight. I just dont know how.
lemons
Home dyno?
Post by lemons »
Im sure theirs a way to calculate horsepower based on a rate of acceleration, combined with gear ratios and wind resistance. I just dont know how.
This post is at:
http://www.msefi.com/viewtopic.php?p=141722#141722
Posted by email.
lemons
Home dyno?
Post by lemons »
This post is at:
Posted by email.
S.Bretz
Post by S.Bretz »
YOu would want to do it in 3rd or 4th gear..its better for datalog to pick up more accurate numbers as the rat of the acceleration of the rpms it less....and yes, there is wind resistance, but you can also calculates that based on the crossestional ares of the front of the car.
If its accuracy that you are loking for, then this is not for you....what it is a decent means of creating something that it pretty consistant. ALl you need to do is find a safe stretch of road and o a couple pulls after modification have been made....what you are looking for really is more a change in the shape of the power curve, not you peak numbers genrated.....but agian that would fall under the guides of know how to use a tool, or not to.
S.Bretz
Home dyno?
Post by S.Bretz »
This post is at:
http://www.msefi.com/viewtopic.php?p=141849#141849
Posted by email.
LT401Vette
Post by LT401Vette »
Being an automatic guy, I would prefer to do all these calcs based on VSS.
The extra ini file already has pretty much everything your looking for in it, but I believe it is based on VSS.
Phil Tobin
EFI Analytics
http://www.efiAnalytics.com/
LT401Vette
Home dyno?
Phil Tobin
93 Corvette 555 cid, MSnS-extra
MegaLogViewer - v2.50 released on 08/27/2006
http://www.ideasandsolutions.biz/MegaLogViewer
This post is at:
http://www.msefi.com/viewtopic.php?p=141858#141858
Posted by email.
Phil Tobin
EFI Analytics
tebriel
Post by tebriel »
there was a piece of software called "streetdyno" i believe that did all of this already, it just needed a couple of inputs. Both myself and ian (http://www.qksltwo.com) ran this and it proved to be pretty accurate.
*think i found it: http://www.tweecer.com/StreetDyno/downloads.html
-teb
tebriel
Home dyno?
Post by tebriel »
-teb
http://www.turbosaturns.net
This post is at:
http://www.msefi.com/viewtopic.php?p=142001#142001
Posted by email.
