I can not get a tach signal with my MS-2 using a GM DIS syst
Does it work on a stim?
Did you assemble it yourself? Have you seen this: http://www.megamanual.com/ms2/V3trouble.htm (it gives tips on what to check if you don't get a rpm signal)
MegaTune will show an rpm on it's tach when cranking (and at all rpms, of course). Showing no rpms suggests you don't have a tach signal.
If it works on the stim, then it will work in the car, if:
- the proper input circuit and settings are used,
- the module is creating and sending the appropriate signal, and
- the harness is actually delivering the signal to MegaSquirt.
At this point, I think you need the factory service manual to help you check your wiring, etc.
Also, you have to hook the tach wire up to the Ref high cuircuit Purple and white. Some DIS have a specific tach output, you may also be able to use that too, but you would have to test to see if it works.
Yes. Make sure you have MT reading the MS unti first. This is easy. If the tps is hooked up, you will see activity for the tps gauge. MT will also have a box lite on the bottom of the screen that will read "Cranking" But you might have to turn your cranking rpm down a little for it to consider the engine as "cranking"...at least I had to.02z24sc wrote:Will I show a signal in Mega tune when cranking the engine or not.
