British Car Beta Testing
1979-mini
Bill Shurvinton
Jean
p.s. I'm using this username because I can no longer use my usual username on this forum and the admin doesn't answer my emails.
1979-mini
A / B Series
I also want to make sure that I have Spark control. MSII should work for what I want, but the small package of the uS is ideal for packaging inside my Mini.
I came to know of MS reading Grassroots MS. I was ready to do the MSII, until I found out about uS.
When you talked about the staged injection, was that comment based on a multipoint injections system?
newtyres1
The uS is not *that* different, I don't think it would be overly difficult to use MS2/Extra code on one. The low-z injector capability is gone (unless series resistors are used), and the second tach input may be different, but the LED outputs for ignition are available at the connector. I've had MS2/Extra (not the very latest version) running on what is effectively a uS, on the bench, no issues. Maybe some simple mods for I/O would be required at most (much the same scenario as if you use MS2/Extra on any PCB with the MS2 daughterboard).
Ian.
racingmini_mtl
Ian,
The difference are not that big but involve playing around with inputs and outputs on different pins and using the timers differently. If you chose carefully the options you use you may be able to get away using MS2/extra on the uS but you are limited. Also, as code evolves the differences are getting more important.
I'm not saying it's impossible but I doubt you'll be able to take the code and have it work without modifications. And if I look at the people who have helped me with the bench testing (up to now no one on the new code), I don't see anyone making the modifications necessary to make the code work on uS. And I'm not the one who's going to be supporting this because it's going to be enough to do it on MS2 (and as i said I don't have, nor will have, a uS). And as the code evolves there are going to be more limitations due to the uS hardware which can't be modified (at least not easily). I don't want to bash uS. It's great for what it does but the expandability is not the same as MS2.
Jean
Bill Shurvinton
newtyres1
Ian.
