MS'ing 45 degree V-Twin
newtyres1
If this new code works well, there will be few oddfire twins in the world that can't have MicroSquirt as an ignition and fuel controller, using a missing tooth wheel on the crank or cam. The uS still hasn't been released, but as far as I know all the hardware has been tested and sorted, so a production run can't be too far away.
Ian.
newtyres1
With a missing tooth crank wheel and no 2nd trigger you have to run wasted spark since MS doesn't know what stroke you are on in the 720 degree engine cycle. Keep in mind this is not true or common wasted spark as it is normally used on car engines (or the older true wasted spark Harley engines), in this case with an oddfire V-twin and 2 ignition outputs and 2 coils, the coils are simply firing twice as often as needed.
Here's some pics:
The derived MS1 work (HD cigs are a collector item shown for size reference only and not to be construed as a smoking endorsement) with MAP Daddy Dual MAP and Opto:
My Buel TB (Mikuni, actually according to the stamp) to S&S Super air filter adapter made from the top of a 22R piston (when you have a lathe, the whole world looks like a problem in roundness):
Backing plate mounted:
Bike completed. I just painted it also. I did the color and clear, my wife did the art. Looks like a giant turquoise rock:
Note eBay sourced adjustable FPR, fuel filter used as a surge pot, fuel return line T'ed in between the filter and the petcock. Fuel pump is the Polaris Victory sourced pump. The one I bought on eBay was bad, of course, so I had to buy a new one from the local Polaris dealer. Initial current drain looked to be 2.5 amps, but it is drawing 4.5 now. Not sure why, but that's within the current specs on the pump for pumping against a load. I wish I had a lower current drain on the pump, but that's what I would up with.
I had to fiddle with the fuel pressure regulator a time or two. I think I'll look around for a better one. I also did a little tweaking on the start parameters and got that better. Highway mileage was about the same as the last really good carb tune I had on it, mid 50's plus/minus wind. About the only issue I had with my install was that the pipe insulation I had covering the fuel pump shrunk some (from the heat?) and the assembly got loose in the bracket I made and slipped down, breaking the + connector connector to the fuel pump. I tightened up the bracket and put a new connector on and that was about it. Given the complexity of the install, I think that's pretty good. Just before we were going to leave, the 2n2222 I had as a fuel pump relay driver cooked, so I had to tear it all apart to replace that with a 2222something from crap shack suposedly rated at a higher voltage and about 17V of zeners across it. I think the flyback on the relay coil cooked the 2n2222. It did fine on the trip.
I had an exhaust leak on my bike, however, resulting in a bit on a delay in the middle of nowhere, SD for some quality time:
but, it was only a 2 day total delay with one day of that wrenchin'. The exhaust leak cooled the valve guide, which dropped down about 2mm, holding the valve open. Started working on it at 0830 and started the bike up at 2130 that night. The valve wasn't damaged (luckily as they are $45 each) so I just had the machine shop put a new guide in and lap the valve.
Besides the fight we almost got into with a bunch of Canadians at the campground, that was about it for adventure.
