Just a quick question, I'm in the middle of wiring up a microsquirt fuel only install with an MSD MC-4 ignition.
The ignition kit grabs the crank position from a Dyna Pro crank trigger.
Question is, where is the best place for the microsquirt to pick up it's signal?
Can/Should i use the same crank trigger as the MSD?
Can/Should i pick up off the coils?
Can/Should i pick up of the factory hayabusa crank sensor?
I don't know if it helps but,
Here is the wiring diagram for the MSD
And here is the factory wiring diagram.
Thanks Again in advance
James[/url]
