How can I set up the stock toothed wheel on my Suzuki Gsxr 750Srad?
I have tryed to be creative, and made this drawing of the wheel and vr sensor...
This is how it looks wheel engine is on its timing marks!:
Are you saying that the wheel that he has will not work, or that a 4-1 wheel won't work?
The wheel he has will not; a 4-1 will. I hadn't seen your reply when I wrote mine. The settings you posted should work with no further changes other than grinding the tooth off.
What you need to do is to make your trigger wheel look like your drawing that I modified. Your settings in Megatune would be like the msq I posted. This is the default msq, so just pay attention to the ignition settings.
Is the exsmple what you are running with?
I thought that I would have to set the "offset (advance) for output #2 for 180 deg?
When the first thooth is out from the picup cylinder 2 and 3 is in tdc!
If you see at the drawing, the thooth the picup is out from, is tdc from 1 and 4!
the grinded of thooth must be number 4?
Set the offset for #2 to 0 and see what happens. You dont need an offset with skip teeth set at 2,because in your case it fires ign out # 1 at the first tooth after the missing one which counts as 1. The second tooth is count 2, so on the third tooth it fires ign out # 2. Then it see's the missing tooth which tells it to fire on the first tooth and keeps on doing the same thing every cycle.
Just out of curiosity I tried this on my test bench this afternoon and it worked fine.
Also you need to make sure you don't have your vr sensor wires crossed.
I know we are working in two different languages here, so I hope it isn't too hard to understand my explanation.
