Dwell has changed!!! Help!
As far as there being no change in the spark timing when you change trigger offset, here are some things to consider:
In dual spark mode, spark must occur before tdc. If it doesn't, it is forced to occur, so if you are really way off then the spark will keep occurring at tdc. Also during cranking, if using trigger rise, then the spark will fire when the tach pulses come in regardless of table advance. The processor has no way of knowing where tdc is except from what you tell it. It assumes that tdc is on the tooth after the missing tooth plus delay teeth and as modified by trigger offset. But if, after considering all this, you see the spark for output 1 coming in x deg btdc and MT says the advance is x deg btdc, then your timing is probably correct and you should be able to change it by 10 deg and see it on the scope.
I made a few changes an it seemed to work fine.
You have allready got your 6 tooth/75 deg offset with your delay teeth set to 5. So you dont need any offset in trigger offset. To set the trigger offset you need turn your motor over and using a timing light get the number you see with the timing light to match the big number you see in the trigger wizard using the +&- buttons.
You have your trigger set to rising edge which means you are triggering on the trailing edge of the tooth.
As far as the dwell, it stayed right at where it was set according to the guage in Megatune. Try this msq. and see what happens.
As Al said, it might be that the data got corrupted was what was causing your problem
- Attachments
- test bench.msq
- Test
- (25.04 KiB) Downloaded 24 times
It was the triggeroffset that was the problem!
Now it is just tuning!
Why did you set the skip pulses in base ignition setup to 3?
It seems like it starts more easy with 1 or 2!?
Maybe you have a good ignition start up map?
How can I set up the microsquirt for the mapsensor I use?
And one more thing, how can I change the range in the RPM gauge in MT?
Here is the msq I used today with suscces
- Attachments
- Engine running, tuning needed.msq
- (25.04 KiB) Downloaded 35 times
As far as the skip pulse setting,this is just what I happened to have it set at. Really haven't experimented with that setting.
To calibrate the map sensor you need to have the specifications for it. If you can't find the spec's you need to find a way to apply vacuum and pressure to the sensor, with an accurate guage attatched and find out what the reading are at 0v and 5v. You then enter these values int the sensor calibration under the tools menu.
I Know it probably not easy for you to aquire, but the MPX sensor is pretty cheap and the spec's for these are in the help file.
To change any of the guage look at this post.
http://www.microsquirt.com/viewtopic.ph ... highlight=
