is there a diy version of this ecu?
substock
Post by substock »
i'm curious as to know if there is a diy kit for this ecu?
but was outbid with 3 seconds left.
i'm just curious, because if there is i may look into one
thanks
'89 Chrysler Conquest TSi MPI'ed
pommie02
Re: is there a diy version of this ecu?
Post by pommie02 »
try diy autotune...they sell kits
SQLGUY
Post by SQLGUY »
For Microsquirt? I don't think so. Last I recall it was pretty clear that, due to the SMD design of Microsquirt, kits were not practical.
SQLGUY wrote:For Microsquirt? I don't think so. Last I recall it was pretty clear that, due to the SMD design of Microsquirt, kits were not practical.
That's correct. Microsquirts are currently only sold in assembled form. (Or more accurately, will only be sold in assembled form once the new batch is ready.)
Gary
Post by Gary »
Any word on the logic-level outputs or 2x18 header version of the board mentioned in the state of the union 2008? I have a V6 application that would really benefit from this.
FoundSoul
Post by FoundSoul »
The new uS box will have selectable high current or logic level spark outputs using BIP373's for the high current drivers. Initially available just as before in a fully cased model with connector/etc. The header-only uncased version will be available down the road just a bit, not sure on the exact ETA but I don't expect it to be too far out.
Gary
Post by Gary »
Cool. thnx Jerry. Will stand by.
Bruce Bowling
Site Admin
Post by Bruce Bowling »
Gary wrote:Any word on the logic-level outputs or 2x18 header version of the board mentioned in the state of the union 2008? I have a V6 application that would really benefit from this.
Its much closer than you think....
The V2 version of Microsquirt board is ready to be run at the contract manufacturer right now, next Tuesday I will go to the CM and check the board out. The V2 board is a minor board change which includes:
- Selectable outputs for ignition, either logic-level or BIP373 driver outputs.
- Resistor in series w/ bootloader signal
- Input for last analog-to-digital channel for MAF option. This is also shared with the pulse accumulator timer input as well, so this one wire will support both analog and frequency-based MAF sensors.
- Increase in VR input series resistance (since most need this).
So with this version checking out, I am ready to submit the "module" version of MicroSquirt. All that changes is the ampseal is removed and replaced with a 0.1" header (2 x 25). Everything else is the same, and the board is all laid out and ready for PCB manufacture. We may not have this board wave-soldered but only the SMT parts soldered on to make it more flexible (and to save cost), since the uses of the board will be different. I have to make up a jig to be able to test the module, using "pogo-pins" to get to the unpopulated signal header. Target price is low US$200.00 or thereabouts, depending on CM and module testing cost.
The module is the size of a business card and will be the most cost-effective EMS for DIY experimenting! Its gonna be sweet!
Paul_H
Post by Paul_H »
Bruce, when will the fully assembled cased version of Microsquirt be available again at retailers?
Bruce Bowling
Site Admin
Paul_H wrote:Bruce, when will the fully assembled cased version of Microsquirt be available again at retailers?
It could be as little as 2 weeks, depending on how fast we can turn the new board version at the CM...
