1) The coil dwell appears to change from idle (just over 8 ms) to some RPM's (just over 4 ms). Is that normal?
2) The trigger wheel. Results show clearly that this is a 18-2 trigger wheel, thus there is 20 degrees of crank rotation between teeth. What's not obvious is which tooth coirisponds to TDC. At idle, the factory service manual said that the timing is 10 degrees advanced. Looking at the "gap tooth" section of the graph, it looks like I may have hooked my oscilloscope up backwards. My big question is, when a tooth passes by the CKP sensor, it that supposed to produce a positive or negitive voltage? I'm wondering because I have the oscilloscope hooked up correctly according what the factory manual calls positive and negitive. If I have it backwards, everything makes sence to me because TDC would be the 3rd tooth off the gap (assuming 10 degrees TDC). I also did a few full throttle pulls, and timing appears to move 20 degress off the idle timing, which would be round 30 degrees advanced, which makes sense (stock engine tuned for 87 octane). BTW, 9k is redline.
Here's the pics. Please give me some feedback.
Idle #1
Idle #2
idle #3
Idle #4
6K RPM @ full load
7k RPM @ full load
8K RPM @ full load
