Off the top of my head, the injector timing is tooth based, so more accurate, the injector timing was fixed to operate coorectly with odd-fire engines, the VR sensing may be a bit more robust, you can apply cylinder fuel and ign trim to a sequential setup, which only applies to 2-cylinder engines for microsquirt. This version also has a better MAF PW calculation. It also has the start of some model-based code which interested people can try. I will release a comprehensive description of the changes next week.
I'm not sure if you have any relations with tunerstudio. I was just wondering if it will be updated at the same time or if i will have to wait until TS is updated to use the new code. (unless I go back to megatune temporarily)
You should just be able to place the new ini that will come with it into the TS project directory and ask TS to change the ini file. I have been using the sequencer with TS for all my recent testing.
