Injector Timing Delay - Single Cylinder
I thought about this after an issue with Ignition timing. I have a 12-1 trigger wheel, on a single cylinder engine, which mathematically would mean skip teeth should be 24. After posting this, Matt told me that skip teeth cannot be greater than trigger wheel teeth, so I should change it to a 2 cylinder and use 12 skip teeth. So I did this, and set up my injector setting for 2 cyl, 2 injector simultaneous, 1 squirt per engine cycle, port injection. This should give me a single squirt during intake. I did not recalculate the req fuel, because it will change, so the only difference will be a wasted spark during the exhaust stroke. I read about the injector timing delay, and basically understood that it is the percentage of degrees between tach signals to fire the injector. Now with the "fake 2 cylinder" setup, I will be getting two tach signals per engine cycle, 1 every 360 deg. So, how will Microsquirt take this into account? Will it want to fire x degrees before both tach signals, even though I told it 1 squirt? Or, will it do one squirt, but during the second tach signal, into the exhaust stroke? How will it know the difference between tach signals? I could try 2 squirts/alternating I suppose, but still, I'm going to have a disconnected injector and I don't that one to be the one firing on the intake stroke. Should I just make a different trigger wheel, or is there something I'm missing? Thanks.
- Master Squirter
Re: Injector Timing Delay - Single Cylinder
EDIT:
Well, I figured things were close enough to try to start it up. I set up my ignition as dual spark with 12-1 crank wheel, and ran both ignition outputs to the coil. This seems to be the key to being able to set my advanced ignition options respective of what they actually are. I timed the engine up so that it fires at the advance mark on the flywheel when cranking (I'm not sure if it uses the advance table when cranking, but my timing light died so I'll have to check later.) I'm not sure about the injector timing setup. From what I read, it is the percentage of degrees of the tach pulses (so 720 degrees for 1 cyl) to fire the injector after TDC. I have this at 60%, which I believe is about halfway through the intake stroke. Anyway, I got it to start and continue running 2 times, by cranking at about 20% throttle and bringing up the throttle when it catches. It won't stay running if I close the throttle all the way though. Most of the time it doesn't start. Sometimes, it sputters, usually after I crank it for a little, then let it sit a few minutes. Nearly every time I crank it though, it will have continuous small backfires through the intake. Seems like a timing issue.
Success there says you have timing and ignition correct. Next you need to verify you have a good tach input signal. Hook the injectors back up, start a datalog, and start up the engine while looking at the rpm gauge. If it keeps jumping to zero or to a very high rpm, then you have a noisy or weak VR signal. If it just dies out but the tach is solid (the trigger +/- column doesn't keep counting up or down), then you want to change the amount of fuel or maybe the advance - whatever you feel is the most likely.
To those curious, this setup is configuration 5a, illustration 3 in the dual spark section of the manual.
