RPM Sensor
Bluehawk116
Re: RPM Sensor
http://www.clrwtr.com/PDF/SUNX/SUNX-PM- ... ensors.pdf
Our wiring of the sensor is the black wire to OPTOIN-, brown wire through the relay that powers the Megasquirt, blue wire to the sensor ground, white wire to nothing, and OPTOIN+ to a 12V source through a 1K-Ohm resistor.
We tried changing the number of cylinders to 2 from 1 under the Injection Control but it didn't seem to do anything to the rpm or to the fact that the injector is squirting every revolution instead of every cycle.
These seem to by our last two problems to overcome before we can start tuning our engine so any information would be GREATLY appreciated.
Re: RPM Sensor
1 cylinder
4-stroke
1 slit on a crankwheel disc
Bluehawk116
Re: RPM Sensor
The msq file we are using is attached.
Additionally, because of limits on our project, the only other sensors we are using are the IAT and Throttle Position with the possibility of a Heated O2 sensor(during tuning only and removed during operation).
We elected not to use a CLT sensor since the engine is air cooled, and left off the map sensor because we were told that the Alpha-N tuning would be most appropriate for our purposes.
Lastly, I'm not sure if it is important but we are using v2.886
- Attachments
- shell012310.msq
- (25.11 KiB) Downloaded 22 times
Re: RPM Sensor
The configuration you have assumes a distributor, so the rpm is double what it really is. The solution to this problem, as Matt said, is to change no. cylinders to 2. This will not hurt anything and I believe it will solve the rpm problem. BUT, I think it didn't appear to work for you because you didn't burn the change and then cycle power. The reason is the RPM coefficient is calculated once at the start, because no_cylinders is not a tuning parameter, but a configuration. The only way changing no. cylinders to 2would not affect rpm is if you didn't burn the change, and then re-cycle power to the ECU.
I believe the 2 fuel injections per cycle will be solved by (on one of the fuel menus) setting "Alternating" instead of the "Simultaneous" in your msq. This will stiil inject every cycle, but on alternate injectors, and you only have 1 injector for your 1 cylinder, so Inj1 will only occur every 720 deg.
Bluehawk116
Re: RPM Sensor
I'm still having problems with the fact that it is injecting twice per engine cycle(once per revolution) I tried as many combinations of injections per cycle, injectors, and simultaneous/alternating that I could think of. It would never let me do 1 squirt alternating with 2 cylinders and 2 injectors which is what I figured it needed to be. Do you have any other ideas of what I could do to rectify this problem?
Thanks again for all your help.
Bluehawk116
