strange rpm signal , the rpm was nearly doubled and everything was wery erractic , not useful at all everything hooked up after the manual, We put a 4.7kohm resistor between optin- and the 12v+ switched , On the other side i used a 500 ohm resistor between the coil negative and the optin+ This worked for me and the rpm signal is clean all over the rpm band , i am using a 2.4 ohm coil on this bike , I hope somebody will have help of this posting here , i should like too see more postings with good solutions , not only trouble, when people have come too and end post your setup , it could be of good help for somebody.
Thanks Lars
