EDIS Help
blake
EDIS Help
Post by blake »
Hi
It would appear I have no ignition advance, stuck at 10deg double checked everything, I have no way of checking the pulse at PIP, would it be wrong to assume that the EDIS module is not generating a PIP? or can the Microsquirt V3 not generate the SAW back to the EDIS? on the laptop all is OK I can see the advance table I can also alter it, but no advance where it matters. I guess what I'm asking is: from the forums experience are the EDIS and Microsquirt modules guilty of this fault?
Alan
Re: EDIS Help
The MicroSquirt is capable of controlling an EDIS module; take a look at the manual, check your wiring and settings.
blake
Re: EDIS Help
Post by blake »
Hi
Double checked and all OK, have tested the SAW from ECU and have 2.5 volts @ idle and 4.4 volts @ 3000rmp tested @ EDIS module, so I'm assuming the EDIS is not seeing the voltage generated from MS, all settings are per MS manual for controlling an EDIS system
Alan
