microsquirt stopped communicating - processor ok?
While trying to tune - communication failed - I was able to reestablish by reloading processor code.
Communications failed again - have not been able to reestablish.
Have verified that 5v exists after the input power stage.
I cannot determine if the processor has failed or if the max rs232 chip has failed or something else entirely.
There is a six pin header on the board - are there signals there that could assist in troubleshooting?
Any suggestions will be greatly appreciated.
Re: microsquirt stopped communicating - processor ok?
What code version are you running? A number of things can cause comms errors, so you should check the tips here: http://www.useasydocs.com/details/connect.htm.
If after checking those you still don't have comms, I would probably try re-loading fresh code (an S19 file, like this: http://www.useasydocs.com/details/usv3code.htm)
You might also want to make sure your bootloader wire isn't accidentally grounded, and that the serial cables are not subject to a lot of noise (which can scramble the comms, and even send the wrong baud rate to the controller, effectively disabling all comms until code is re-burned).
michael
michael
