Microsquirt V3 on Yamaha Banshee project - R6 Map sensor ?'s
Thanks a bunch! I'll put up some pics of the project later tonight.
- Master Squirter
Re: Microsquirt V3 on Yamaha Banshee project - R6 Map sensor
I know the R6 is a Mitsubishi part, and there is a possibility the service manual for the R6 gives a calibration curve diagram, like my GTS1000 ones do, but I haven't been able to check. I doubt the Nippon Denso curve I have is any good, so I'd suggest you test it...
Hook the up to 5V & ground, and measure the signal voltage using a multimeter and silicon tubing a tee piece connected to a vacuum gauge & a medical type syringe.
Start at nothing (open) or 1 Atmosphere, connect the hose to the sensor, and it'll be around 4.65-5V. If it isn't, it'll be greater than 100kPa to compensate for a ram effect possibly, so it'll read a lower voltage.
Then suck the air out, and record the pressure & volt readings.
They are usually a straight line plot, V vs kPa (or as near as dammit).
I know it's work, but I got a dinky Denso one too with my Aprilia TBs, and would have done the above, if I didn't get lucky in my searches.
That's basically what I ended up doing with a mityvac. I fiddled around with the numbers in TS until it read correct numbers for -29.9"hg and atmospheric pressure. Math says this means it's a 2.5bar sensor. Glad to know I'm covered if I ever decide to boost it!24c wrote:Hi,
Yeah, I found a copy on the net, only thing it said was around 3.6V at atmospheric pressure.dontz125 wrote:I have the 03-04 R6 manual in my library, and no, it does not have a calibration curve.
For reference of anyone else, the specs I came up with are -100kpa = 0v and 160kpa = 5v. This gives correct reading of 101.5kpa with the sensor out in the open and -98kpa with mityvac sucked down to 29".
Here's some pics, took about 12 hours yesterday and today of wiring work. Need to tape and loom it up now.
Wohoo! LC-1 wasn't powered up so that's why 02 reading is off.
